blocke outside drain
Posted: Tue Mar 29, 2011 3:33 pm
by mike green
my foul water drain,kitchen sink,washing machine and soon to be dishwasher,backs up outside,the trap fills ,overflows and drains down the drive,eventually draining away.i have tried a short wire toilet unblocker ,no joy and now tried a caustic chemical ,no joy
i would like to avoid dynorod costs .can anyone help[bournemouth]
Posted: Tue Mar 29, 2011 9:53 pm
mike green,
If you are referring to an outside gulley you will have to get a hand down into it to clear the invert and outpipe.
Posted: Thu Mar 31, 2011 12:52 pm
by mike green
did the hand down the gulley/trap ,brought up some mud/silt but the blockage seems to be out of reach
Posted: Sat Apr 02, 2011 6:23 pm
mike green,
Did you manage to get your hand "round the bend" and clear the outlet pipe, this has to be your priority before going further.
Posted: Sun Apr 03, 2011 11:32 am
by mike green
unfortunately to get any further into the drain i need triple jointed wrists
and very long arms
Posted: Sun Apr 03, 2011 12:49 pm
by Kenj
A set of drain rods is the best bet for tackling this problem. These can be purchased relatively cheaply from DIY stores, or hired from a Tool Hire shop, and will certainly be cheaper than calling in Dynorod.
While the rods are too rigid to bend around the u-bend, using the 4" flat rubber end piece you can force water through the pipe with some force. This may well dislodge a build up of fat, hair and tissues etc.
If this does not shift it, then tackle the problem from the other end, the sewer manhole. Use the rods to push the blockage the other way, towards the u-bend and gulley.
