MOVING A PRIVATE DRAIN AND WATER BOARD PERMISSIONS
Posted: Tue Jun 26, 2007 1:47 pm
by DUDE DIY
I intend to move a private drain when I extended my kitchen. Just wanted advice on....1. is it best to get drainage plans or a survey from local water board? 2. Should i get permission to move my private drain in writting from the water board before starting work?...has anyone out there had problems with there local water board after they have completed simlar work. Thanks
Posted: Fri Jun 29, 2007 9:54 am
by jondeau
It's your drain, you can do what you like with it.
I can't see the water company being interested.
On new housing builds the Building Control department of the local council checks and approves drains.......and if you really want to get involved with the beaurocracy ask them.
I can't recollect a single instance of small builders/plumbers ever bothering.
JD.
Posted: Sun Jul 01, 2007 8:14 am
by DUDE DIY
