PLastic Bung or Plug stuck in 4inch Drain Pipe - Any Other Options for Removal?
Posted: Sun Mar 08, 2015 8:13 pm
by dl7984
Hello
I have a drain bung that is stuck in a drain that I am looking to connect to a new toilet. As seen in the image it is 5m in from the manhole and is in a drain that is 4 inches wide.
I have had engineers come around and attempt to remove it using a power flush and with rods. The problem they had with the rods was that there was a curve in the pipe which meant they didn't have a straight run at the blockage and so couldn't get their full force behind it.
I know this can be resolved through an excavation, but I wanted to know if there are any other options available to me.
Many thanks
Re: PLastic Bung or Plug stuck in 4inch Drain Pipe - Any Other Options for Removal?
Posted: Mon Mar 09, 2015 11:45 am
by thedoctor
Other than excavation you have two very,very long-shot options. Use drain rods to try and loop a lassoo rope around the thumb screw on the bung or make a hook out of a piece of steel, attach it to a rope and use the rods to try and get the hook round the back of the bung. Both have been known to work but very time consuming indeed.
