Some Fairly Basic Questions on Shower Pumps and Towel Rails
Posted: Fri Sep 11, 2015 10:21 am
I wonder if anyone could answer some fairly basic questions on shower pumps and towel rails please?
1. In the past I have had a towel rail supplied with heat via the domestic hot water supply. This means that I have warm, dry towels throughout the year and don't have to rely on having the Central heating on. can I have a new towel rail installed in this way or is this now illegal or considered to be an undesirable situation?
2. If I can't have a towel rail heated by the domestic hot water supply and end up having to install a dual fuel rail, what are the rules in terms of an electrician wiring up the element? Does the supply have to be taken all the way back to the main circuit board or can he take a spur off a nearby socket (located outside the bathroom, obviously)?
3. Can someone please give me some honest explanations in relation to a shower pump. My cold water tank is located in the loft, more than 60 cms above the shower head. The hot water tank is on the same floor as the shower, in an airing cupboard in a study adjacent to the bathroom. I currently have an Aqualisa shower pump on the floor of this airing cupboard. As part of refurbishing the bathroom and installing a new shower cubicle I want to fit a new shower pump (the old one is many years old has some sort of push-button vacuum switch to turn it on - I have had to replace this push-button in the past and I gateher that they are no longer in common usage). I have been told (by Stuart Turner) that I need to fit a "Negative head" shower pump, a local plumber's merchants tells me and everything I have read seems to suggest that I only need to fit a "Posittive head" shower pump. What shoul I fit and why?
4. Can someone please explain whether I should use a 2 BAR or a 3 BAR shower pump and why?
5. Finally (sorry about this), would there be any down side to having the shower pump also supply the bath mixer tap?
Sorry for being so long-winded (and stupid), I would be very grateful for any helpful advice.
