Dog Leg Hot Water Tap Being Moved 15 Feet From Boiler and Need Pump
Posted: Mon Mar 07, 2016 10:45 am
We hare having our kitchen extended outwards which means the kitchen taps will be 15 plus feet away from the Combination boiler ( the type you get hot water directly from)
Is there any type of pump, or other appliance, which you can have inserted that transports the hot water more quickly to the tap so that you don't have to run and waste the water?
