Leaking Y Splitter Under sink
Posted: Sat Oct 13, 2018 8:22 pm
by xsamx1987
Hello all ok so I fitted a new brass y splitter I will provide link to the exact one i bought
I have used plumbers tape and all new washers
But for some reason I have a slow leak from where it connects on to the main pipe
Is there a special way I should fit it with my hand or a tool?
https://www.amazon.co.uk/Splitter-Manifold-Washing-Machine-Connector/dp/B01LVYWN8A/ref=cm_cr_arp_d_product_top?ie=UTF8
Re: Leaking Y Splitter Under sink
Posted: Sat Oct 13, 2018 11:56 pm
by KitchenGuy
Don't use plumber's tape, it is not appropriate for this sort of fitting. The knurled end has a rubber washer in it which makes the seal. Putting tape on it would most likely cause it to tighten up before the seal is engaged. Make sure the rubber washer is in place, then just hand tighten, put some grips on the knurled ring and just nip it up, approx a quarter turn or even less. This sort of fitting does not like being over tightened or it will damage the seal.
Posted: Sun Oct 14, 2018 2:51 pm
by collectors
Looking at the fitting i would of thought some good washers & pipe grip's should be enough. This is assuming you are not fitting any sort of adaptors.
Posted: Tue Oct 16, 2018 12:15 am
by xsamx1987
Thanks Guys now seems to be water tight :)
