Toilet Water Levels in Toilets in new Property
Posted: Tue Sep 03, 2019 5:51 pm
I've just moved into a house that has high water levels in the toilets. One flushes properly - eg, water/waste drains away and then the bowl refills with clean water. However, the other doesn't drain, but the water fills to the rim and then drops back to the normal level (which is quite high for UK). I have flushed the pipes so I know it's draining properly but how do I get it to empty before refilling with clean water?
Any advice much appreciated. x
