Triton Milan 2 electric shower unit Help
Posted: Wed May 27, 2020 6:45 pm
by Biggsy
Hi all, new here and just after some advice.
I have a Triton Milan 2 shower unit that is brand new. We fitted it after the old unit would cut out after around 10 minutes. The shower power would remain on and live but the water would stop. The original unit was quite old so I bit the builit and bought a brand new one. We still have the same fault though. I have Googled some suggestions and found the most common fault might be the solanoid valve, however this is a brand new unit although when I measure it I'm not getting any ohm reading, suggested reading is 3.5-4. So, it suggests that it may be faulty but I can't see how on a brand new unit displaying the same fault as the old one. Could there be anything else electrical causing the solanoid valve to stop working?
When I speak to a plumber they tell me it's an electrical fault, when I speak to an electrician I'm being told it's a plumbing issue. I'm trying to get to the bottom of this now as it's been ongoing for almost a year now.
Re: Triton Milan 2 electric shower unit Help
Posted: Thu May 28, 2020 10:36 pm
Hi biggsy
The first thing to check is the water pressure specifically when there is some draw off. This is the most likely cause of your problem. The new shower will specify minimum pressures.
Regards S.
