Recommended replacement make/model for Aqualisa Aquastream Mk 2
ScoobyDenver
by ScoobyDenver » Sun Aug 09, 2020 8:35 am
We have inherited an Aqualisa Aquastream MK2 power shower, which now needs replacing. (It has gravity fed hot and water pipes, plus booster pump)
We need to put in an equivalent which will cause minimal disruption, to the rest of the bathroom. I.e The nearest u can get to a straightforward swap!
One option is to get the Aqualisa Aquastream Mk3-which might be most straightforward, so Seems quite appealing, but I wondered if you can recommend a different make (maybe cheaper) that might be a good match? I don’t really know where to start with a decent equivalent.
I wondered in your experience, if you can easily say - ‘go for this model and/or definitely avoid this one!’
Any advice gratefully received!
It is currently Tue Dec 03, 2024 8:01 pm
