Reduced cold water flow after hard frost, possible leak?
Posted: Wed Feb 17, 2021 11:29 pm
I have a combi boiler and a mixer tap over my bath. After a period of hard frost I WONDERED (NOT CERTAIN) if the cold tap was running at a lower flow than previously and feared a leak. However, I have established that both the hot tap and the cold tap are delivering exactly the same amount of water. Does that suggest that there is not a leak?
Does a combi boiler control the water flow to the hot tap and the cold tap and make them exactly the same?
Thank you very much in anticipation of your kind assistance.
