Is this layout suitable when moving pipes, WC and basin?
Posted: Wed Oct 27, 2021 9:26 am
Hi I'm redoing my bathroom and part of that involves moving the waste pipes into the floor void rather than being visible above the floor.
The WC and Basin unit will be next to each other and I want both wastes to drop down into the floor before turning and exiting through the external wall. Here they will connect into a cast iron downpipe using McAlpine Push-Fit Single Socket Drain Connector (https://www.screwfix.com/p/mcalpine-pus ... 10mm/4255v)
My concerns are the location of the join between the 32 and 110mm pipe and also the vertical drops
Any guidance appreciated!
