Fitting an extractor fan for a bathroom
Posted: Tue Nov 29, 2022 3:39 pm
Hi all
Would appreciate some advice please for fitting an extractor fan in the bathroom. I'd like to do this myself to save costs and then have an electrician in to do the wiring.
I plan to fit it to the ceiling, and run the ducting through the loft to an existing hole through the wall which is around 5' above the loft floor. Not sure what size/power fan I need, bathroom is around 7' x 7' and total duct length would be around 7'
Also, what type of ducting best to use - flexible or solid? upvc or aluminium? Flexible is easier, i guess, but how to insulate it when most of it will run vertically? Do i still need to insulate if I use rigid plastic?
And if i get a fan with a backdraft shutter do i also need a non-return valve on the external cover? If so, would i need a more powerful fan?
Thanks in advance for any advice you can give me.
Michelle
Michelle
