wiring of electric oven
7 posts   •   Page 1 of 1
diy rob
by diy rob » Mon Apr 23, 2007 8:28 pm
I am about to fit our new kitchen, the old one I put in over 12 years ago and the oven simply pluged into a 13amp socket with never any problems. I am being told the new oven which has a total connected load of 2.8 KG will need to be hard wired,? Can anyone confirm if I would still be able to plug it into the same 13amp socket.? If not whats involved in order to hard wire.?
by sparx » Mon Apr 23, 2007 11:37 pm
Presume you mean 2.8 kWatts?, if so this equates to 12.17 Amps so should work on 13A socket...
If more then you need a dedicated circuit which comes under part p rules and you need to read the projects section ref. part p & decide on cost effectiveness of trying to DIY against G S I (get someone in)
Regards SPARX
diy rob
by diy rob » Tue Apr 24, 2007 7:25 am
Many thanks Sparx for your fast reply. :lol: Rob
diy rob
by diy rob » Wed May 16, 2007 7:48 pm
Just about to order the new oven (Neff No B1422). Although reading that it is 2.8KW we have also read somewhere on a web site that the model in question needs a 16amp fuse?
Would this now mean that it will need to run direct from the consumer board (HARD WIRED)? or can I still run off a 13amp fused isolation switch or can I put a higher fuse in the switch?.
by sparx » Wed May 16, 2007 11:19 pm
Hi Rob, 2800w divided by 230v = 12.17A.....
16A is continental socket type, Neff is Continental make so not Anglesised in hand book, run off 13A fused connection unit as better connection than plug & socket, no probs. regards SPARX
diy rob
by diy rob » Thu May 17, 2007 7:11 am
Hi sparx. Again thanks for your fast reply. I will ask now what may seem to be a daft question . Reguarding changing for the fused isolation switch. "Can I still plug into the socket under the counter top and connect the oven to that with a 13 amp plug once that is in place."?
I'm trying to cut down the need to pull tiles off and change wires ect.
Again. "Many thanks"!
Rob.
by sparx » Fri May 18, 2007 1:28 am
Yes but make sure all wires properly in plug & TIGHT, as close to max load, regards SPARX
It is currently Thu Dec 12, 2024 4:41 pm
