New electrical installation - lots of questions
Posted: Sat Apr 12, 2008 9:13 pm
I have recently purchased a small plot of land with an old stone barn. I'm in the process of renovating the barn (not converting – it will be used as a barn) and have just had the power company in running electrics to it. So far I have a meter, main fuse and 100A isolation switch fitted in an external meter box. The cable has been run to the barn from the pylon in a trench (approx 60m).
1. At some point work is going to be done on the roof and it will likely not be waterproof for some time. Can I have the consumer fitted in something waterproof? I was thinking of getting another meter box but would prefer something a bit more slim line.
2. I would like power to an area remote from the barn (approx 150m-200m away). Can I reuse the trench, which is still currently open, in which the cable the power into the barn is laid.
3. With a run of this length do I need to start worrying about anything above the normal considerations for running power to an outbuilding?
Colin
Colin
