CALLING ERICMARK
Posted: Sun May 18, 2008 10:21 am
by BLAKEY1963
hello sir its BLAKEY1963.
DO u know if there is link for flexishield cable ???????????.
i need the info on it for a quotation.
thanks 4 your help
Posted: Sun May 18, 2008 10:52 am
Flexishield is available from Cleveland Cable Company
Think its made by TPWCC and they don't have the WWW in front of their name and it is a dot com think TCWCC stands for "The Pre-wired Conduit Company" The Cleveland Cable Company is a WWW one still dot com I have hunted for the price and not found it may be better trying IET web site and their forum where I first found it existed. Problem is no one pays full price for cable so even if you do find price not much help. Please let me know how you get on and if you do work with it what it is like to work with.
All best Eric
Posted: Sun May 18, 2008 10:55 am
by BLAKEY1963
[quote="ericmark"]Flexishield is available from Cleveland Cable Company
All best Eric[/quote]
THANK U ERIC
Will try and get info , and let u know.
BLAKEY1963
Posted: Sun May 18, 2008 10:58 am
Found it
2.h - BS8436 Protected Fixed Wiring Cable, 1mm to 6mm
Fixed Wiring and Mains Cables - Plain annealed stranded copper, XLPE insulated, tinned annealed stranded copper earth wire, bonded aluminium tube applied longitudinally, low smoke and zero halogen (LSZH) outer sheath, to BS EN 50267-1:1998 and BS EN 50268-2:2000, UV Stable. 600/1000v to BS8436, White.
Posted: Sun May 18, 2008 11:00 am
CCC Code Conductor size
(MM2) Stranding Cores Weight
(KG/KM) Overall
Diameter (MM) Gland
Size Cleat Trefoil
Cleat
FSX2X1WH 1 7/0.44 2 85 8.6 20S - -
FSX3X1WH 1 7/0.44 3 105 9.4 20S - -
FSX4X1WH 1 7/0.44 4 130 10 20 - -
FSX2X1/5WH 1.5 7/0.53 2 106 9.8 20 - -
FSX3X1/5WH 1.5 7/0.53 3 140 10.4 20 - -
FSX4X1/5WH 1.5 7/0.53 4 158 11.3 20 - -
FSX2X2/5WH 2.5 7/0.67 2 135 10.8 20 - -
FSX3X2/5WH 2.5 7/0.67 3 182 11.1 20 - -
FSX4X2/5WH 2.5 7/0.67 4 259 12.6 20 - -
FSX2X4WH 4 7/0.85 2 206 11.5 20 - -
FSX3X4WH 4 7/0.85 3 265 13.1 25 - -
FSX4X4WH 4 7/0.85 4 320 13.9 25 - -
FSX2X6WH 6 7/1.04 2 258 13.1 25 - -
FSX3X6WH 6 7/1.04 3 328 14.2 25 - -
FSX4X6WH 6 7/1.04 4 450 14.9 25 - -
Now I have part numbers may find more!
Posted: Sun May 18, 2008 11:58 am
by BLAKEY1963
[quote="BLAKEY1963"][quote="ericmark"]Flexishield is available from Cleveland Cable Company
THANK U ERIC
BLAKEY1963[/quote]
ERIC
JUST got into cleveland cable company website.
have mailed them a query about flexishield.
let u know when they reply.
BLAKEY1963
Posted: Sun Jul 06, 2008 7:43 pm
I saw a post where you said you had more information including a sample but the forum is all up the creak and would not let me reply.
I did find another make.
Prymian Earthshield
Prysmian Afumex LSX (Has higher voltage but still to BS 8436)
Prysmian Cables & Systems Limited, Marketing Department
Chickenhall Lane, Eastleigh, Hants, SO50 9YU
Tel: 023 8029 5029 Fax: 023 8029 5437
Some of the cables are also FP200 fire resistance but there was a note about types of MCB to be used and I think only Type B can be guarantied to trip.
I am all ears
Eric
