hi folks,
still renovating the house that we moved into in november. pulled up the floorboards in my son's bedroom to fit the last radiator on the new heating system and noticed some 1½mm² cable going into a junction box under the floor - old red and black T&E with white sheathing so obviously done last time the house was rewired (badly) 20 years ago.
what caught my eye is the 1mm² cable with grey sheathing, the newer type, that also goes into the junction box so clearly an extension of existing. closer investigation shows that the new T&E is feeding the outside light by the front door.
all the outside lights are on a separate loop. the run of the 1mm² cable is about 4 metres and to change it for 1½mm² cable would be a great pain. so can i leave it as it is? i know that normally the same thickness of cable as the circuit should be used when adding a spur.
the light fitting uses a low energy bulb and is the only light being fed from the 1mm cable. what concerns me is that the light is a dusk til dawn so its on permanently throughout the night.
i will change it for 1½mm² but only want to do it if absolutely necessary! any advice greatly appreciated.
