Sticky external 3-pin socket
Posted: Fri Jun 13, 2008 4:19 pm
by sean.cody
I have an external 3-pin socket. Its proving very hard to withdraw any 3-pin plug I use in the socket. Its so sticky I now risk pulling the socket off the wall. Is there any suitable / safe lubricant I can apply to the socket to remove the problem. Pls advise on this or any alternative solution. Thanks.
Posted: Sat Jun 14, 2008 4:31 pm
by kbrownie
HI sean.cody,
What do you mean by external socket? is this located outside?
I personally would advice you to replace the socket-outlet but firstly check it is not the plug that is not causing the problem with bent pins!
Reagards
KB
Posted: Mon Jun 16, 2008 9:59 am
by sean.cody
External = outside
Its sticky for all plugs, so I guess that means I ought to replace the socket then.
