lighting spur from ceiling rose
Posted: Sat Jun 14, 2008 4:45 pm
The flat my brother recently moved into has 3 wall lights which he wants to remove and book floating shelves. It looks like it is running from a spur from the ceiling rose.
I'm however confused with the wiring:
- The neutral from the light pendant is connected to the switch terminal. And the live is connected to the neutral terminal.
- Looking at the 2 gang dimmer light switch for the pendant connection, the wires are indeed swapped around. So i guess this is why it works.
BUT, why
- On the switch there is there a wire going from the live of one gang to the neutral of the other.
- And on the ceiling rose, there is one terminal connection that has a live and neutral wire connected to it (from different cables - not sure which).
BUT, why
