consumer mcb
Posted: Sat Jul 26, 2008 2:54 pm
is it possible to ruin a consumer unit mcb by wireing a light switch wrong
I fitted a new light switch before doing so I switched the lighting mcb to the off position switched and the light worked I then connected a second light to the switch and the mcb would not switch to the on position even with the consumer unit off I have since then disconnected the light switch but the mcb will not go to the on position I have been told that wireing the light wrong could damage the mce but I thought that they would be more robust than that any info would be great my consumer unit is hager 8 way unit
