Wiring light switch (pull switch already wired)
Bighandal
by Bighandal » Mon Sep 29, 2008 12:34 pm
I've got the following :
Pull switch (3 terminals)
1 = 1 x Black & 1 x Yellow
2 = 1 x blue , 1 x red
3 = 1 x red
Light (3 blocks of terminals)
1 = 1 wire to light, 1 x black, 1 x black
2 = 1 x red, 1 x red, 1 x red
3 = 1 wire to light , 1 x black
Cable into switch box
1 x yellow
1 x blue
1 x red
1 x earth
Switch
L1
L2
Com
earth (I know this one !!)
Which of the wires goes where to the L1 / L2 / Com terminals ?
Many thanks
by ericmark » Mon Sep 29, 2008 6:03 pm
I would say Red to Com and other two (Yellow and Blue) to L1 and L2 does not matter which way around as long as Com is correct.
If you look at http://www.ericpalmer.fsnet.co.uk/Lighting.html this shows a number of diagrams to how two way switches are wired if you want to understand what you are doing.
I am assuming standard wiring and the red wire in pull switch is also wired to com. It is simply like for like with the methods I show.
Eric
It is currently Wed Feb 05, 2025 10:49 pm
