Can i install a new Radial circuit in my kitchen?
dannyrobson
by dannyrobson » Tue Sep 30, 2008 11:17 pm
I need to move my Electric Oven to the other side of the kitchen, i was wondering if it is ok for me to remove the old flex from the fuse box and install a new longer cable to the new location?
Also i could do with adding a double socket for kettle microwave etc.
I would feel confident doing this but i am not part p certified.
How illegal is this if atall? :D
by ericmark » Wed Oct 01, 2008 1:31 am
You are allowed to do anything you want under Part P if you pay the council their fee and are skilled enough to do it.
We don't know your skill so can't say if you personally can do the job but the real question is "Is it worth it?" Fees vary but let me assume £70 plus you will need to hire test equipment at another £70 by time you add the £140 to the job it is often cheaper to get a registered electrician to do the work. You may be able to get council to do the testing for you again depends on council.
Rules say you should test and submit results if they don't like them then they can re-test at their cost to verify in some cases they will just test but depends on council.
There is a link on the projects section to Part P
As to what if you don't well insurance may not be valid and you may have problems if you come to sell the house.
Eric
It is currently Wed Feb 05, 2025 10:53 pm
