Garage Electrics
Posted: Fri Oct 03, 2008 12:10 am
I have replaced my garage but it's new location is further away so the cable from the consumer unit is too short. Is it Ok to fit an external junction box to the outside wall and then run the extended cable from that to the garage consumer unit/ RCD? Or do I need to replace the cable all the way back to the consumer unit so it is one long cable to the garage RCD.
Other tips/ advice appreciated, if junction box is ok then where to find one with suitable amps for outdoor mounting.
Many thanks
Many thanks
