CookerHood wiring
Phaedris
CookerHood wiring
by Phaedris » Fri Oct 10, 2008 10:57 pm
I recently got an electrician to give me a qoute on the installation of a cookerhood.
He said the best way to install it would be to tap into the wiring for the socket nearby and then run a cable from there to the hood.
Here is a diagram
http://img399.imageshack.us/my.php?imag ... ng2zx5.jpg
I was just wondering if this is the best way of having the cookerhood installed?
by ericmark » Sat Oct 11, 2008 5:30 pm
You give no measurements but I would think "No" is correct answer.
1) Must follow save zones.
2) Junction boxes must be available for inspection.
I will also point out.
a) Will now require RCD protection.
b) It comes under Part P
Because of heat I would consider ali-tube cable.
Eric
Phaedris
by Phaedris » Sun Oct 12, 2008 4:01 am
Thanks for your reply.
I live in Ireland so part P wouldn't apply.
Would it still be the incorrect way of wiring it up?
The reason I decided to post a question about it was because he seemed alittle dodgy, and just wanted to know if the way he was saying to wire it up was correct.
by ericmark » Sun Oct 12, 2008 2:26 pm
I am told Ireland uses the same red book as us and BS 7671:2008 or 17th Edition still applies but the legal enforcement may be different.
Eric
It is currently Wed Feb 05, 2025 7:58 pm
