Sparks ? from Jeffmo
Posted: Thu May 17, 2007 8:10 pm
by Jeffmo
Ref : Meter tails , with reference to sparky conn and discon do sparkies carry those funny metal seals . Strange question i know , cheers , hope you enjoyed your hols . Regards Jeff
Posted: Fri May 18, 2007 1:12 am
Not legally!
We used to have an arangement with supply authority whereby they would sell registered contractors some numbered plastic seals (yellow),and if you unsealed cutout you resealed with your plastic one and notified them & they would change for metal (nomal) seal later.
since privitisation they won't play, ECA & other orgs . keep trying but dealing with several energy suppliers not easy,
regards SPARX
sparks? from jeffmo
Posted: Sat May 19, 2007 6:29 pm
by Jeffmo
so am i right in thinking that only lecky company can pull main fuse? or do you have to call them in just to put the silly little tags on . Cheers mate Jeff
Posted: Sat May 19, 2007 10:06 pm
Officially u should talk to them first, the reason seals there to stop tampering with supply, not forgetting if you make a mistake on pulling/refitting fuse several thousand Amps can flow until short circuiting item vapourises........B.W. SPARX
