outside toilet light.
Posted: Fri Feb 06, 2009 2:45 pm
by s1bgs
there is a light in o/s toilet on its own fuse in cu.
Q. can i take supply from switch to supply a new light in adjacent shed.
Also can i fit a socket in shed by taking spur from kitchen socket using an FCU. Do i need to tell building control. thanks
Posted: Fri Feb 06, 2009 6:09 pm
s1bgs,
Yes you can but you will need RCD protection and the shed is a notifiable location so comes under Part P. You should get BC incolved or use a certified and registered installer.
Posted: Fri Feb 06, 2009 7:07 pm
by kbrownie
If your wiring it yourself you will need to notify building controls, as this comes under part p of building regulations the installation will need to comply to BS7671 and as you are adding on to exsisting circuits a minor works certificate will be needed too.
KB
Posted: Fri Feb 06, 2009 8:13 pm
hi, it depends on which way the light is wired, if supply goes to sw. then on to light then run from sw. if supply goes to light first then loops to sw. then extend from light.
However to extend ANY wiring out side main house is covered by building regs 'Part-p' & is a 'controlled service' see 'projects section'
regards SPARX
Re: outside toilet light.
Posted: Fri Feb 06, 2009 9:43 pm
by dunabit
[quote="s1bgs"]there is a light in o/s toilet on its own fuse in cu.
Also can i fit a socket in shed by taking spur from kitchen socket using an FCU. Do i need to tell building control. thanks[/quote]
any work involving a kitchen must be notified as its a special location
hi sparx
Posted: Sat Feb 07, 2009 9:22 am
by s1bgs
[quote="sparx"]hi, it depends on which way the light is wired, if supply goes to sw. then on to light then run from sw. if supply goes to light first then loops to sw. then extend from light.
regards SPARX[/quote]
thanx for ur reply. the shed is more an out-building attached to the end of kitchen in old victorian hse and not seperate as in wooden shed in gdn (still need to go outside to get to it). socket would be on RCD as kitchen ring seperate and RCD`d. just need to drill through 9 ` wall for cable.
