Plastering over cables
Posted: Fri Feb 13, 2009 9:24 pm
by greg-s
Hi, I'd be glad for your advice please on whether cable can be plastered over directly or does it have to run under a protective cover or tubing. In this case it's a spur using 2.5mm to a socket. The cable length is 2mts. Thanks - good to have found this site.
Posted: Sat Feb 14, 2009 11:03 am
by kbrownie
HI greg-s,
They can be plastered straight over with out any mechancical protection, providing the cables are routed within the permited areas.
If they are not routed within these area they need to be buried at least 50mm in to wall surface (that includes both side of a partition wall) or have mechanical protection.
It is advisable to protect the cable though from damage that the plasterers trowel may cause, so not a requirment but a good idea.
KB
Posted: Sat Feb 14, 2009 11:10 am
by rosebery
It should be mechanically protected (capping or oval conduit). Capping protects it from the clumsy spread and his sharp trowel (:lol:). If you use conduit then the cable can be easily replaced if necessary later or another cable added if necessary and if the conduit is large enough.
KB is correct in that there is no actual requirement not to plaster over directly. I would argue that it's not good practice though.
Posted: Sat Feb 14, 2009 7:55 pm
by greg-s
thanks for the advice guys
Posted: Mon Feb 16, 2009 6:15 pm
greg-s,
If you are installing a new spur and cabling different regulations need to be complied with.
Posted: Mon Feb 16, 2009 9:57 pm
by kbrownie
Hi stoneyboy,
I would be interested to know what different regulations are applied to protecting a spur from mechanical damage?
The regulations regarding addition and extending circuit is a different matter.
A minor works cert is needed
KB
Posted: Tue Feb 17, 2009 9:44 pm
kbrownie,
Sorry my term "different regulations" is a bad choice of words they are after all the same regulations.
Perhaps we should have asked greg-s whether the spur is an addition - if yes then we would have to suggest a more stringent standard of protection or RCD/RCBO fitted on the circuit.
Thanks.
Posted: Wed Feb 18, 2009 10:30 am
by kbrownie
Hi Stoneyboy,
no worries, just thought I had missed something, earth leakage devices very useful part of systems. May be should have mentioned them in earlier posts.
Was really thinking of mechanical protection rather than shock protection, but good point.
KB
