Changing a light socket with red, pink and yellow/green .
Posted: Thu Feb 19, 2009 8:49 pm
by heatherlalor
Can anyone help? Changing socket and I have red, pink - tow of each as its a double switch socket, and yellow/green(this is connected to box) - which is live and neutral. I am wanting to swap with a double dimmer.
Posted: Fri Feb 20, 2009 9:18 am
by singer
Hi Heatherlalor
Could you confirm is this a socket that you plug into or is it a switch that switches a light on or off? You refer to both in your question so a bit confusing!
Posted: Fri Feb 20, 2009 10:11 pm
by heatherlalor
[quote="singer"]Hi Heatherlalor
Could you confirm is this a socket that you plug into or is it a switch that switches a light on or off? You refer to both in your question so a bit confusing![/quote]
\Hi sorry, it's a double light switch - I have had another look I have two black wires with reds sleeves, two pink and one yellow/green which is connect to the metal inner box.
Posted: Fri Feb 20, 2009 10:17 pm
by heatherlalor
It,s a double switch. There are two black wires with red sleeves, two pink wires and one yellow/green which is connected to the inside of the metal box.
