1 light on, all the rest dead
Posted: Mon Mar 02, 2009 3:14 pm
by SpWhale
I have just replaced a light fitting in my hallway. Having completed the fitting and tested the light it works, however ALL the other lights in my flat are now dead. There is power to all wall sockets so tv etc all work, just the lights that are out. I have tried new bulbs in each fitting but none work so I have eliminated blown bulbs.
The wires were red and two blacks, I am 100% on this having checked with a torch before installing. My concern is that I had put the live wire to the neutral first then switched the wires and got the light working. I believe i had the fuse box off at all times although I wonder if its that which has blown. But surely then my hall light would not work either?
Help, I am literally in the dark!
Alex
Posted: Mon Mar 02, 2009 7:57 pm
by fraserd
how many wires are there? and what colour?
Posted: Tue Mar 03, 2009 9:14 am
by moggy1968
the lighting circuit is a radial circuit so lights will work as far as the fault, in you case the light you are working on. After that nothing will work. There should be another red cable that loops out to the rest of your lights. this needs putting with the red cable you have which is your live feed. there should then be another red which is the liveto your switch which is also red. a black will then come back from the switch which should(but not always) be flagged with red or brown tape or sleeving. this connects into the same block as your brown wire on the light fitting. The blue from the light fitting goes with the other black as these are neutrals.
so, I think you have some more cables to find. Your current light has a live feed (red), but that live is not being taken out to the next light on the circuit.
Andy
Posted: Thu Mar 05, 2009 6:27 am
by SpWhale
Thanks Andy that makes a lot of sense, there weren't any other wires coming out of the light fitting itself although there were others in the ceiling directly above but these were all running off elsewhere, I didn't see any other bare wires. I think I'll need to get someone in before I do any more damage.
