80W towel rad in WC
Posted: Sun Mar 15, 2009 3:28 pm
by Vincenze
Have bath-shower area separated by stud wall and folding door to toilet and corner basin. Want to put IPX1 34 elec rad in by basin. Supply through switched fuse, load – short wire from rad will need extending in sealed terminal connector. Supply and load go via pull cord ceiling switch.
Then realised Part P. Shall I just jack it in - get competent person? Or does this fall under storage heater fitting?
Thank you
Vince
Posted: Sun Mar 15, 2009 9:17 pm
by kbrownie
It's not a storage heater,
part p does apply as in a special location do the right thing call a suitable qualified electrician.
KB
Posted: Sun Mar 15, 2009 9:58 pm
by rosebery
Yes get yourself a sparks as its electrics in a special location as defined by Part P. Also you'll need to get inside the stud and insert additional noggins where the rad will be attached to the wall (unless you are luckey enough that the fixing points just happen to fall over the studwork). Otherwise all that will be holding it up will be the plasterboard - not recomended.
Posted: Mon Mar 16, 2009 10:04 am
by Vincenze
Load wire protruding from solid wall by wall mounted cabinet. Probably was shaving point or vanity light. God knows where it is coming from.
I'll do the right thing and call a comp person.
This site is the dogs.
A
Posted: Mon Mar 16, 2009 6:51 pm
by kbrownie
HI Vincenze
The cable will more than likely come from the above lighting circuit. So if this is the intended supply to your electric rad, check the ampage being supplied as it may not be suitable for a large powered rad.
If it's a 6amp mcb it will only allow a max of 1380watt.
KB
80 watts
Posted: Tue Mar 17, 2009 1:34 pm
by Vincenze
Very low power – only 80 watts. To be left on all winter to take chill off, warm towels etc.
Posted: Tue Mar 17, 2009 9:36 pm
by kbrownie
The fuse rating will be low then but as previously mentioned Vincenze, it is in a special location does need to comply to BS7671:2008 and installed according to the building regulation part p. So as much as I am happy to give advice as are most people on this forum get yourself an electrician, it's for the safety you, your family and property.
Kind Regards
KB
Posted: Sat Mar 28, 2009 2:07 pm
by Vincenze
Understood. Thanks.
