Security Light
Posted: Sat May 16, 2009 4:44 pm
i want to install 2 security lights with pirs outside my home which purchased from wickes (702839). which is the best way to go about installing them.it says about putting a switch inside so you can turn it off manually and to use 1mm or 1.5mm2 flexible 3 core cable. Also could you have both lights running off the same switch
Many thanks
Many thanks
