advice about rcd
Posted: Sat May 26, 2007 2:52 pm
by bazza
hi i hav decided to change my wylex fuses with the replacement plug in mcb and i waz wondering is it worth fitting a rcd i have been told that the rcd can be fitted as a seperate unit if that is correct which would be the best way of fitting it and are there any restrictions on where about on the curcuit they hav to be THANX bazza
Posted: Sat May 26, 2007 6:30 pm
Hi Bazza
two ways, of doing it,either fit in tails between meter & wylex board, or fit in outgoing circuits to sockets. Both have merit/probs.
First way puts lights on RCD which can cause unwanted tripping if lamps blow, also if trips at night due to fault on any circuit it takes out lights as well, hazardous if 1/2 way up stairs etc.
second way means having one RCB per circuit you want to protect, expensive!
either change board for split-load board, or decide on other choices
regards SPARX
P.S. don't forget it's part p work whichever way u go!
Posted: Sun May 27, 2007 3:35 pm
by bazza
thanx 4 reply sparx gonna take your advise and hav a split-load board n i think ill get the experts in on this one CHEERS bazza
advise about rcd
Posted: Sun May 27, 2007 5:56 pm
by bazza
hi sparx thanxs 4 reply gonna take your advise n go with the split-load board but i think i will get the experts in 4 this one CHEERS mate bazza
