can I use spotlights in a ceiling with a concrete roof...
Posted: Sun Jul 19, 2009 5:45 pm
by j4cse
I am putting up a new plasterboard ceiling which has battens on a concrete roof. Would it be better to use 12v spots for the main lighting instead of the 240 due to the lower heat generated and the fact that I will not have any access from above to the lights with it having a concrete roof, or would it be easier to use 240 with not having to have a transformer to conceal, though I only have about 60mm clearance so this may limit my options with the 240v...?
Many Thanks
Posted: Sun Jul 19, 2009 7:53 pm
hi, very little difference in heat since watts = heat irrespective of voltage!
as you say transformer will just be an added problem, stick with mains light
regards Sparx
spotlights
Posted: Sun Jul 19, 2009 10:11 pm
by j4cse
cheers, yeah, if I am able to find some mains lights that will fit into the roof space as only about 60mm clearance. with 12v spots they seem to require much less space, its a low ceiling anyway so lowering it wont really be an option.Do u know if there are mains spotlights that are able to fit in ?.
Posted: Mon Jul 20, 2009 12:35 am
by moggy1968
60mm is probably the wrong side of cutting it fine even on 12v, they need about 90
Posted: Tue Jul 21, 2009 4:28 pm
by kbrownie
Spotlights or down lights?
What is the roof above ie garage or a living area?
Can you put in a false ceiling?
