Confusion with pull light switch
Posted: Sat Aug 08, 2009 2:26 pm
by kdp99
While decorating I am replacing a light and its pull switch above the bed (but not the main wall switch). I was going to do a stright swap but the pull switch has become disconnected so I can't.
The light has the normal black and red in, wired to blue and brown on the light - no problem.
The pull switch (which always opperated OK, but in a slightly odd manner) has three cables, RED, BLUE, ans YELLOW. I've used a 240 AC volt meter and tested which pairs of cables have 240V across them, the results are:
With the main wall switch off there is 240V between Blue and red only,
With the main wall switch on there is 240V between Red and yellow only.
My question is which of the three colours should be wired to which terminals on the new pull switch. (not worried if it opperates as before, or in any other way.)
Many thanks
Re: Confusion with pull light switch
Posted: Sat Aug 08, 2009 8:28 pm
by dtomes2003
The pull switch should have 3 terminal connections.......'COM', L1 or A1 and L2 or A2.
Judging from your description, the red cable (usually called the switch live) should be connected into the 'COM', the blue into L1 or A1 and the yellow into L2 or A2, depending on which type of pullswitch it is. (the yellow could be connected into the L1 and vice versa........). It dosen't usually matter, as long as the switch live (the cable which connects to the light) is identified........
If there is still a problem, look at the wall switch connections and copy that.
Sorry, i couldn't explain it any better.......
Regards,
Darren
[quote="kdp99"]Hi
Many thanks[/quote]
Posted: Sun Aug 09, 2009 5:57 pm
by kdp99
Many thanks, works fine as you suggest.
