Turning oven on = Boiler triping
Posted: Wed Oct 14, 2009 9:30 pm
by Dallasgside
I replaced my electric oven and ever since, when I turn the new oven on the boiler will trip. I cannot see how I have gone wrong? All I have done is wire the cooker into the existing point that the old one was wired into.
Is this a simple/common fix? Or do I need an electrician to sort this out?
Any guidance would be greatly appreciated
Cheers, Dallas
Re: Turning oven on = Boiler triping
Posted: Thu Oct 15, 2009 3:38 pm
by BLAKEY1963
[quote="Dallasgside"]I replaced my electric oven and ever since, when I turn the new oven on the boiler will trip. I cannot see how I have gone wrong? All I have done is wire the cooker into the existing point that the old one was wired into.
Cheers, Dallas[/quote]
DALLASGSIDE
obviously assuming u have made the connections ok , then u could have a fault on your cooker circuit.
Best to get in an electrician with the appopiate test gear to
check thing over 4 u .
BLAKEY1963
Posted: Thu Oct 15, 2009 4:23 pm
by steve the plumber
I'm guessing that the cooker and boiler are NOT on the same circuit.
This should be checked out by a competant leccy as the boiler should not trip when the cooker is turned on.
