Flashing light?
Posted: Fri Oct 30, 2009 10:48 am
Hi, small problem. I installed some low voltage downlights in a bedroom cupboard with a PIR sensor hoping it would switch on when the doors are opened. I took a live(loop) and Neutral from the bedroom light fitting to the PIR following the PIR's instructions and then to the transformer.
I powered it up, the bedroom light came on alrite but when switched off, it started flashing.
Any ideas what i have done wrong??
Thanks.
Thanks.
