Buzzin In Bulgaria
Posted: Fri Jan 01, 2010 5:07 pm
Hi Guys & Happy New Year
I'm a Brit expat living in Bulgaria and have a really annoying problem affecting my VOIP telephone - a conversation stopping buzz which appears to be triggered by at least some appliances and I would really appreciate some help please if anyone can see an answer.
When the problem first started I stripped my computer system down, tried different phones but could not pinpoint the problem. Recently, with the weather cooling down, I put an oil filled radiator in the same room and noticed as soon as it kicked in the buzz would start ... switch it off and the buzz instantly stopped. I then checked this with the cooker (because the problem appeared to be worse in the evenings), it too had the say affect and to a lesser degree the kettle. However, sometimes even when none of these are on, the buzz can still happen; more in the evening when power demand increases - I'm wondering?
Bulgarian power supply leaves a lot to be desired, especially in a small village and recently; the power went off several times and when checking to see if my computer was still running I smelt burning. What had actually happened was, when the power came back on it was at a greatly reduced voltage; lights were dim and the burning I smelt was something in the 450w PSU of my computer burning out ... through low voltage?
If anyone can see a cause/effect pattern above and any possible solution, it will be good to hear from you.
Many thanks - Scott.
