Cooker hood query
Posted: Thu Feb 11, 2010 2:13 pm
Hi folks - second question I'm afraid!!
In my flat the builders (it's a newbuild) decided to put a dodgy extractor fan near to the cooker (the type you'd have on a wall with a pull cord). It has an isolation switch on the wall at worktop height.
I have purchased a cooker hood from screwfix (the glass one) and it has a plug fitted to the end.
The extractor that I want to take out is rated at 25 watts, and the cooker hood at 230 watts. The cable to the extractor fan is, I believe 2.5mm2, so should be adequate to carry 3amps or more, which I believe is more than adequate for the cooker hood (at 1 amp).
The problem I have is knowing what I can do regarding connecting the hood. I have a loft space above the kitchen, which is where the cable runs for the existing extractor fan.
As the position of the cooker hood means there is plenty of this cable to accomodate it, I was thinking that I may be able to put a switched socket on the end, and locate it in the loft space (on the upper side of the plasterboard as it's a suspended ceiling).
I do not know though if i did do this if it is in breach of Part P of the regulations. The cable is existing, and it is replacing an existing appliance, but the fact I am putting a plug socket on the cable is where I'm unsure if I am ok to do this (as it is in effect outside of the kitchen).
Sorry this is a bit long, and hopefully not too confusing! I can get some pics if required (not sure if I can upload them to the forum though).
Thanks in anticipation of any help.
Dan T.
Dan T.
