installing celing mounted lights
jblw
by jblw » Thu Mar 04, 2010 11:40 pm
Hi everybody
Thanks in advance to taking the time to read my questions,
I am building a garden room, i want to use ceiling lights, maybe LED, open to other suggestions.
The construction of the room is flat roof timber frame, with a 6 inch gap between roof and ceiling, but i will have 100mm kingspan insulation.
Can i use this type of lighting, what are the implication's of heat etc.
Can you dim LED, would love some recommendation.
I will again need to run cables what is the recommend routing of cables, again implications of heat build up.
by stoneyboy » Fri Mar 05, 2010 10:59 pm
jblw,
If its a warm roof construction use fire rated downlighters which take GU10 lamps and fit low energy lamps in them.
If its a cold roof construction you will have to find lights which fit below the ceiling.
jblw
by jblw » Sat Mar 06, 2010 12:24 pm
Thanks stoneyboy,
Top words of advise, thanks.
James
It is currently Fri Jan 17, 2025 6:04 am
