3 phase motor Question -No neutral
Posted: Thu May 13, 2010 10:23 pm
I was instructed to wire up a 3ph industrial extractor fan , 3ph Spindal, 3ph planer.
Everything was going fine until I came to the final connections where I got a little stumped. (bearing in mind I haven't attempted any 3ph motors in nearly 3 years). I looked at the wires: green/yellow, brown, blue and black.
I was under the assumption Blue was (N), Green/Yellow (E), Brown (Ph), Black (Ph). I was missing a grey(?).
Called up the manufacturers and asked the questions regarding the cables and was told that the 3 colours (Brown, Black, blue) were the phases. No NEUTRAL?
Could some one give me a little 'masterclass' on what I am overlooking?
I thought there needed to be a return ie: Neutral.
I have tried to go over it in my head and the only conclusion I can come up with is that the motor consumes the power it needs there for eliminating the requirement for a return neutral.
Am I completely off the mark? As per usual all your knowledge passed on in always valuable.
Kindest regards,
Sparkydelux
Kindest regards,
Sparkydelux
