Approximate costs of moving and upgrading fuse box
Posted: Wed Aug 18, 2010 10:25 pm
Please note I am not qualified to do any of this myself and apologies if I have used any wrong terms – I need the costs for a house I’m considering buying. which is a three bedroom bungalow. Thanks everyone.
Cost of replacing a fuse box with a new latest type of consumer unit and carrying out a periodic inspection check?
Cost of removing the fuse box and installing a new consumer unit in the hall (10 yards away) and then carrying out the periodic check? Am I right to assume this will need an isolator switch to go where the fuse box originated from?
Finally is it possible to have everything moved (fuse box, meter, isolator switch from its current position 10 yard into the hallway - and what would that set me back?
