Outside installation using a domestic 4-gang socket?
Posted: Mon Sep 06, 2010 9:34 am
Hi - was out over the weekend and saw an electrical safety issue at a commercial visitor paying attraction.
240V single-phase AC dropped from upper floor of a building and lying across the ground outside.
From this cable a normal domestic indoor 4-gang socket lying on damp grass was connected inside an open gazebo (2 cash registers were then run off this socket).
Now I was told the cable that was dropped into the gazebo was rubber sheathed trailing lead and is waterproof and the attached socket is to IP 56 standard. Also the distribution board to which this was connected was protected with RCD's. Furthermore they said the domestic 4 gang extension should not have been left out in wet conditions and there will be no recurrence of this and in future such arrangements will be protected from any damp or wet environments.
By the way, the rubber sheathed cable with the IP 56 socket was "flying" and not anchored to anything, so it was bearing weight directly and could flap around in the wind.
Is all this sufficient regs wise, or should I still be concerned? Seemed like they were relying solely on the 30mA RCD trip if the 4-gang had shorted and I guess they shouldn't be using that outside, RCD or not...?
Thanks, hoping you can give me some quck and simple advice here. I don't want to be a snitch and I have not got it in far anyone there; just trying to prevent someone from being electrocuted...
