changing from pendant lighting to spotlight
mrgav30
by mrgav30 » Sun Sep 26, 2010 4:56 pm
hi i am changing my pendant lighting to a 3 plate spotlight however my spot only has 3 terminals and my pendant has nine, am i right in thinking i attach all the live and all the neutral into there own terminals?
belsparky89
by belsparky89 » Sun Sep 26, 2010 10:21 pm
you need to put the switch wire in a terminal of its own. the switch wire will be the one that is connected to the same terminal as the live on the pendant fitting (put abit of tape on this cable to identify this cable). all the neutrals and earths should be connected together. the 3 terminals u have are live, neutral and switch live. an earth terminal should be present aswell. but if not just put the earth cables into connector blocks. gd luck
by sparx » Tue Sep 28, 2010 7:03 pm
belsparky89
read your answer again please! im sure you didn't mean
"all earths & neutrals should be connected together"!
I'm sure you know what you meant but it reads very misleading to the OP
sorry but we have to be very carefull when answering not to assume knowledge levels.
regards
It is currently Thu Jan 30, 2025 11:34 pm
