Workshop Electrics
Posted: Thu Oct 14, 2010 7:06 pm
All single phase 240 volt feel free to ask for more info.
Crabtree household consumer unit split load was run from an 100amp fuse outside, replaced approx 5 years ago with a 65amp and wire tagged! Hob actually draws 32amp.
Main concern is one machine with 1 1/2hp non cap start motor continually blowing a 13 amp fuse 1 in every 3 startups, hot or cold. Run from consumer unit with 20amp RCD. It never trips the RCD.
Welder on lowest setting in to same socket will trip same RCD at inapropriate moments spending more time actually resetting RCD.
Just as a matter of interest i have an old 3hp English induction motor, non cap start that blows a 13amp fuse every time, bridged it starts up and runs no problem with no effect on any of the sockets plugged into.
Same but different circuit RCD's feed separate sockets.
3hp motor when running will trip the RCD when turned offor upon startup.
1hp motor with a low current DRO plus a US transformer is now starting to trip another RCD.
I know i have a Bosch fridge that causes problems on the house side, even so cannot remember the last time anything tripped an RCD.
Any ideas what to do - starters, 16 and or 32amp industrial sockets etc.
