double light switch for 2 seperate lights.
Posted: Wed Jan 26, 2011 4:15 pm
by dave6953
please help,I have changed from a single light switch to a double switch to use on 2 seperate lights.the double switch has com.L1.L2.top and bottom.the wires I have are 2red.2blue.2earth.how do I wire these up.
so what I am doing is adding an extra light.thank you.
Posted: Wed Jan 26, 2011 5:45 pm
by collectors
This image link might help.
[url]http://i23.photobucket.com/albums/b387/COLLECTORS-INFO/dimmerwiring.jpg[/url]
Posted: Wed Jan 26, 2011 11:58 pm
One pair red and black to com at top and L1 at bottom.
Second pair com bottom L1 top.
L2's are not used. However if switch works wrong way changing from L1 to L2 will swap which way is off and on.
The earth to terminal on backing box if there is one. If not just tape up.
Posted: Fri Jan 28, 2011 11:06 am
by dave6953
[quote="ericmark"]One pair red and black to com at top and L1 at bottom.
The earth to terminal on backing box if there is one. If not just tape up.[/quote]
hi ericmark,I tried what you said but it still does not work,the one light works,(the original one)but the new light will not work,what I did not mention was. The second light is an outside security light.thank you.
Posted: Fri Jan 28, 2011 11:09 am
by dave6953
hi collectors,got link ok,thanks for your help.
Posted: Sun Jan 30, 2011 1:41 am
I am guessing that some one has tried to connect a second lamp to the light switch rather than the ceiling rose.
There is no neutral at the light switch so one can't take a supply from the switch.
Posted: Sun Jan 30, 2011 8:59 pm
by dave6953
thank you so much ericmark,I understand what your saying,I think I will get a professional in to do the job.
