Wiring an appliance direct to a double socket
Posted: Sun Jan 30, 2011 9:56 pm
Hi, I am installing under unit strip lights to my kitchen wall units and wondered if I could simply wire the lights into a double socket which is directly beneath them on the wall. Obviously there will be no fuse (as no plug due to directly wiring them into the socket) which is why I am wondering if it is safe to do it ? If I have to connect the lights to a fuse socket could I use a cooker double socket as I notice that I have a cooker double socket with a simple cooker 'on / off' switch and a traditional socket (which you can put a plug in) next to it. As there is no plug facility for the cooker I imagine that the cooker is wired direct into this socket so my thinking is that this part of the socket must be automatically fused ? I'm a novice so I might be way out here but any advice is appreciated, thanks
