replacing a light switch
Posted: Sat Feb 05, 2011 1:41 am
by bizzle
any help will be very much appreciated....
im redecorating my extension and want to add more light (we currently have 1 fan/light) which is very dull.....
i would like to add 2 more lighting circuits and be able to switch each circuit individually from one point in the room....
can i get a 3way lighing switch and basically "loop" the incoming feed to each switch so i can have independent control for each circuit?
if no... then what is the best wasy of doing this????
many thanks
andy
Posted: Sat Feb 05, 2011 4:32 pm
Yes from lamp "Loop" you daisy chain to next lamp "Loop" and so on then switch cable from each lamp to each switch.
Note:- Normally no neutrals at switch so loop from lamp to lamp. However sometimes loop is taken switch to switch specially when using extra low voltage lamps so check first.
