Odd problem with fluorescent light strip
Posted: Tue May 03, 2011 10:49 am
by Reynard
I've a fluorescent light strip (single tube fitting) in my kitchen that's been doing something really strange the last couple of evenings. It's something I've only noticed when the room is dark.
Usually, when I turn it off at the wall switch it turns off completely no problem. But right now, it turns off, then starts to glow a sort of pale blue-grey. The glow swirls around a bit, then dims, then comes back etc.
When I take the starter out, it gets worse - I noticed that when putting in a new starter, but that hasn't really cured the issue.
The tube itself is quite old and a friend has suggested electrical interferrence from somewhere. But beyond putting in a new starter or replacing the tube I'm out of my depth, so I'm wondering whether anyone can give me a heads-up and whether it's worth speaking to an electrician.
Re: Odd problem with fluorescent light strip
Posted: Thu Jun 16, 2011 10:13 pm
by AideLiuX
Reynard wrote:I've a fluorescent light strip (single tube fitting) in my kitchen that's been doing something really strange the last couple of evenings. It's something I've only noticed when the room is dark.
I thing the problem is that neutral wire have some voltage.Its need to check with meter. If it is it is not safe anymore use your light strip.
Posted: Thu Jun 16, 2011 10:19 pm
by AideLiuX
The problem is that som how neutral lightning wire gets from somwhere voltage.Check swith i thing he is not cuting power well or ther is burnings inside.Electricity go trugh them.
Posted: Fri Jun 17, 2011 7:46 pm
HI, try turning tube around, end for end.
