SY Multi Flex 2.5mm 3 core
AjayK46
by AjayK46 » Sun Jul 31, 2011 11:28 am
Is this flex suitable for making up a portable extension lead (about 10 mtrs) for outdoor use?
Can appropriate 13amp plugs etc be fitted to it easily or is it more like SWA?
by ericmark » Sun Jul 31, 2011 10:49 pm
Depends on make. Some have a copper strand under the braid and easy to sleeve and connect to earth. With others though one has to push back the braid tease open a hole and pull the flex through it then careful elongate the braid again to make it thin enough to connect to earth. Not so bad with Commando type blue plugs where the hole in earth pin is larger than rest but near impossible with a 13A plug.
It will also depend on size of cable. A 1mm sq cable has diam of 9.5mm which will not fit in most 13A plugs so the clamps will grip outer so not really suitable for 13A plug.
AjayK46
by AjayK46 » Wed Aug 03, 2011 6:44 pm
Much appreciate your help.
by ericmark » Thu Aug 04, 2011 11:54 am
You could terminate into a Commando type blue plugs then use an adaptor to 13A plug.
It is currently Wed Jan 15, 2025 6:39 pm
