Earth in dishwasher plug burned through
Posted: Sun Dec 04, 2011 9:12 pm
by boycy
Hi all,
Dishwasher stopped working - checked the plug and fuse is fine, hasn't blown, but the earth wire looks like it burned off at the terminal. Doesn't look like it was well-connected in the first place though, not much left inside the terminal housing.
Just wondering - would it be safe to rewire the plug straight off or might it be risky if the earth already burned through without the fuse going?
Cheers in advance,
Rob
Re: Earth in dishwasher plug burned through
Posted: Tue Dec 06, 2011 5:41 pm
Under normal use no current flows though the earth wire. For what you describe there must be a major fault. So no it's not safe to rewire plug. It's call an electrician time as likely there is damage to socket. Also one questions why it should happen. So really does need investigating.
Posted: Wed Dec 07, 2011 11:42 pm
by boycy
Ok will do - thanks for the advice Eric :-)
