Fitting new socket plate
the2ems
by the2ems » Thu Jan 12, 2012 10:53 am
When fitting a new socket plate to a metal wall box, should I connect the earth from the back of the plate to the earth screw on the box?
Re: Fitting new socket plate
by ericmark » Fri Jan 13, 2012 10:46 am
I have seen electricians argue over this. Some feel the two 3.5mm brass screws are ample and there is no need for extra earth wire others point out that until the item is removed one does not know if socket faulty or no power so back box should be earthed with small bit of cable.
It does get heated at times but unless to earth the back box means there are far too many cables going into the earth connection then I see no reason not to connect.
It is currently Thu Jan 30, 2025 3:13 am
